Door step light
vmatador
Los Angeles
I'd like to change the bulbs in the door step lights to LED. I was able to to remove the entire step lamp case (it has metal clips on the sides) and disconnect the connector easily. However, I could not remove the clear plastic lens, which has 4 plastic clips. Any idea how to remove the lens??
To get the lens off after you get the housing off, you have to pop it off. Bro it's so easy lol. The clips just hold it on. Take your fingers and pull it apart. It's not that hard :)
