Just something I have been working on. The spacers available for the FX are either 5mm and use the hub to center the wheel, or are 15mm and have a machined lip in the spacer (to extend/replace the OEM hub lip). I'm trying to stay away from using the spacer to center the wheel.
I wanted the minimum spacer required to clear my Stoptech brake calipers, which would be right at 7mm thick. I came up with a centering jig that can be removed after the bolts are all torqued down. I just drew this out in PowerPoint, so if anybody has any design ideas or improvements - I'm open.
At first I thought I would attach the jig so that it and the spacer are permanently attached to the hub (until you remove them). My reasoning was that the weight of the wheel will sit on the jig, and after the lugs are tightened down, the lugs and the hub take the load.
But for now, I am thinking to remove the jig. As long as the wheel is centered when the lugs are torqued, the jig won't be taking any load. I think. So it can come out. The jig is the small stepped cylinder. The first page is just to get the dimensions worked out. The second page is assembly. Black is OEM components and blue is the jig and spacer.
This way, the wheel will sit on the jig while you thread the lugs. Once tightened down, the wheel SHOULD be centered, so the jig can slide out.
If there is still a load on the jig after the lugs are torqued, then maybe we can come up with a way of fastening it to the OEM hub - maybe using the axle threads, or using set screws or something.
Comments welcome. Also - if somebody knows a place to have these jigs made cheap - I wouldn't mind a little collaboration in figuring out something that works elegantly.
