Decided to try out some new wheels after seeing Humberto's iForged Sprints.
To be a little different, went with iForged Imola in 24"x10" in brushed aluminum and chrome lip.
Build: 2 piece (no barrel bead to leak!)
Spokes: 10, brushed aluminum
Offset: +45mm, will run 25mm adapters, so +20mm offset (yes, very aggressive)
Bolt pattern: 5x120 (ours is 5x114.3)
Center bore: 72.56mm (ours is 66.1mm)
Lip: 3 inch front and rear, chrome
Adapter: custom 25mm aluminum with black anodizing, hub and wheel centric, 12x1.25 thread. No shaving of OEM studs needed.
Weight: 38 lbs per wheel, 40lbs shipping weight (pretty happy about that)
Tires (haven't fully decided, maybe try 295/35/24 -- but on a dropped FX, probably will not clear inner front strut).
285/30ZR24
Pirelli PZero Nero M&S Ultra High Performance All Season
400 AA A
103W XL (103 load index = 1929 lbs, W rated = 168mph)
Overal diameter: 30.7"
weight: 32 lbs/each
rim width range: 9.5-11"
Set of steel inserts in case I ever want to slightly CNC mill press drill the existing holes. Not sure if the tires would clear the front H&R spring unless I went coilovers with the +45mm offset so decided on adapters.
This was a set that was in stock and no wait time, so I jumped on it.
http://iforged.com/us/wheels_detail.php?WhID=25
Stock photos:
Finishes available:
Actual photos:
Stock tire photos:
285/30ZR24
400 AA A
weight: 32 lbs/each
Stock photos:
Finishes available:
Actual photos:
Stock tire photos:
