mrmumford08
- west linn OR
so i am one of the very unfortunate people to be having an overheating issue with my 05' fx35 as well. i was on my way home last night when i noticed engine temp light redlining:mad.:. shortly after, my gas wasnt accelerating the vehicle (a safety measure by the ECU im assuming.) I quickly pulled over and had smoke/steam billowing from my engine :mad.::mad.: and when i went to pop the hood noticed all my coolant had expelled onto the ground:mad.::mad.::mad.:. MY FX HAS 82,000 MILES ON IT. reading these forums are making me scared out of my mind because im only 21 and i spend almost my entire paycheck on my car. im way strapped on cash and cant be affording to spend money on parts that dont need replacing so im really hoping someone can give me advice. anyhow i got home from work today and refilled the radiatior and reservoir with water to see if i could find any gravitational leaks (did not do pressure test because i dont have the tools.) and i couldnt see anything. Then i proceeded to Follow instructions by my dealer I try to reproduce the overheating effect by reving my engine to 2500rpm and allowing the engine to heat to its normal operating temperature and everything was running fine except a few small noises i have not heard before "water sloshing." If anyone can just please explain to me how often they have it occur? do you wait for it to cool down and drive it again? i dont know what first steps to take, theres so many things (water pump, thermostat, radiator and/or radiator cap, pin hole leak in the head gasket???? and the people that work at my local beaverton infiniti shop here in oregon sound worthless like how everyone else on this thread describes theres to be
