I got air bubbles in the ABS Actuator. How did I got air in ABS Actuator? I sucked out too much fluid from the master cylinder when I was change out the brake fluid.
The brakes on my FX35 is very soft. Anyone knows of a way/method of bleeding the ABS Actuator other than going to the stealer dealer? I've bled it with the 2-man method, vacuum, and injection methods multiple times and it still soft. So I took it into Firestone last night to have them bleed it, they told me there is no air bubble in the lines and everything is working fine. They suspect there are air bubbles in the ABS Actuator. They hooked two different scanner tools (a Snap-on and one other one. They said they' were very good scanners) to it to activates the solenoid valves but its no go. The Snap-on was able to communicates with the ECU, but cannot activates the solenoids. The other one was not able to communicates with the ECU. They suggest to go the dealer or someone/shop that have scanner tools that can activates the ABS solenoids.
