305/35/22
illestFX35
Los Angeles/Glendale
2010 FX35 RWD
anyone running this size squared on there FX with 22x10.5? should i run these or 285/40. i will be running 22x10.5 +40. any suggestions on which brand i should run? dont want to spend alot on tires.
285 is better either 35 or 40. 305 is a lot on the front and you may run into clearance issues. Plus it will make the slow speed steering heavier.
thank you. im thinking about which tires i should buy before i purchase my wheels so i can just get the mounted and balanced right away. do you have any suggestions for 285/40?
You would probably be better at the 285/35r22 size, much more variety.
yea but i really want to run 40 because i wont be lowering and if I do it will only be springs. I want to fill up the wheel gap as much as possible while not offsetting the speedo. I would've run hankook ventus rh06 if they werent discontinued. can anyone give their input on their favorite tires?
I have seen mixed reviews on the 420s. Search it on the forum here.
---------- Post added at 06:06 AM ---------- Previous post was at 06:05 AM ----------
At 35 or 40, the speedo will be off a hair either way.
I had 305/35R22 mistakenly installed on my FX by Discount Tired couple years ago and I tell you it's hella meaty. I recognize something was off immediately. On my previous set, it was 22x10.5+25 and boy, did those tires rub and pop the plastic fender trim pieces off.
