Ok so below is the recommended 30k service, and then below that is my dealer recommendation. Please see all pictures below. Keep in mind I have the FX50 S.
So here is what I'm planning:
- Oil change
- new wipers (I need them and really like the stock ones cause they have a clear no branding look)
- 2 engine filters I guess replace
- grape in-cabin micro filter
- front left/right seat filters
(the above 3 filters I'm thinking of having them do it the first time just so I can see the cost and then afterwards decide if I'll do it myself is what i'm thinking, but I don't know I keep flip flopping on it)
- transfer case oil
- rear differential oil (no where does it say front differential so not sure if it is covered below when they say in the sheet rear differential service....not sure why they wouldn't do front if that is necessary to unless this is part of it?)
from their suggestion: I was going to tell them not to do the coolant (100k, but will do at 60k), not do trans fluid change (100k, but will do at 60k). But not sure why on their list rear differential and transfer case is not on it? Also they have listed under recommended AWD / 4x4 service for $310? What the heck is that? Could that be transfer case, but that seems way too much then. Their prices are actually cheaper than other Infiniti dealers around here.
I don't plan on doing anything with the tires because they are driving fine, balances, and all even wear so why mess with it and pay for nothing?
If I individualize, then maybe I won't get all those other things like parking brake adjustment. Do I really need that, never did it on any other car before?
And whats the deal with infiniti suggesting replacing radiator cap? Never ever did that on a car before.
Infiniti also recommends replacing engine drive belts but dealer doesn't have that either in their list? Not sure about this either...I never have replaced mine on previous cars before unless they started squeaking...almost seems like throwing away money.
then I wonder why they don't list cleaning sunroof drains on their list. They detail everything there....that's weird considering some of you guys have mentioned that. I wonder if dealerships normally don't do that.
Thanks guys for helping me decide what I should/shouldn't have scheduled. I trust you guys more than the dealership since dealerships in my experience recommend too much and just throw away money lots of times.
- Oil change
- transfer case oil
