22 wheel help
singlide
arkansas
taylor
Hey guys so I need to buy new wheels asap. I am really wanting 22's. I am a big fan of most of the niche sport series wheels. I am having a hard time figuring out which offset is right. I am waiting to run 285/40-22 with no drop factory height. I have the fx50s factory big brakes. Someone please lead me in the right direction my fx is on jack stands lol thanks
I got perfect flush on my 1st Gen, I'm running 24 x 10 ET45 plus 25mm wheel spacer. So with the 25mm spacer, my offset becomes ET20. My understanding that the hub on the 2nd Gen tuck in a bit more than the 1st Gen, so I think 10.5" wide with ET25 should be good.
What offsets are the Niche available in? That will be a big factor, you can't pick any offset you want. Let us know what your choices are, then we can give you the optimal one.
looks mostly
I have put a set of Milan wheels on a G37 with akebonos and they fit fine
they were staggered 19s with a +40 offset and they cleared no problem
For the record, no problem with 22 x 10.5 ET40 wheel + 25mm spacer with 285/35R22 tires.
---------- Post added at 03:09 PM ---------- Previous post was at 03:05 PM ----------
There an extreme concave design
Doesn't look extreme concave, but even if it was, +25 is fine. I have 10.5" concave and the front is +35 before spacer. It brushed my akebono calipers before I put a 25mm spacer on. But +25 has more room.
STR 607 in 10.5". They're concave and the +35 brushed the calipers until spacer. I have 1st gen but Akebono retrofit and relative distance between caliper and wheel is the same.
22x10.5 +25 with 285/40-22 on stock suspension
---------- Post added at 11:55 PM ---------- Previous post was at 11:53 PM ----------
I love how it looks but with the factory suspension the wheels stick out more than i prefer. I may get fender flares from i-gear.
