2003 - 2008 Infiniti FX35 FX45 Kido Racing Coilover Group Buy LIVE
2003 – 2008 Infiniti FX35 FX45 Coilover Group Buy
1) Chedman13 (Chicago, IL) 12KG Front / 12KG Rear - PAID
2) la_fx35 (Chicago, IL) 10KG Front / 12KG Rear - PAID
3) FX45Chicago (Chicago, IL) 10KG Front / 12KG Rear - PAID
4) Slamming45 (Chicago, IL) 10KG Front / 12KG Rear - PAID
5)
Buddhist_fist (Vancouver BC, Canada) spring rate to be determined - awaiting PayPal e-mail and spring rate decision
6)
JLee (SF Bay Area, CA) 10KG Front / 12KG Rear - invoice sent
7)
Jcasanova (Houston, TX) 10KG Front / 12KG Rear - PAID
8)
Logan (Seattle, WA) 12KG Front / 12KG Rear - PAID
9)
FX4BR (La Jolla, CA) 10KG Front / 12KG Rear - invoice to be sent (let me know spring rate too if 10kg/12kg is okay)
10) AeroBFA (Chicago, IL) 10KG Front / 12KG Rear - PAID
11) KNFX (Houston, TX)
12)
13)
14)
15)
Thanks! I really had no intentions of getting coilovers but then I started to visit iS again. This place is a bad influence. :D
Video of Kido Racing Coilover testing on a Mazda Miata MX-5 testing at Mobara Twin Circuit Chiba, Japan.
[video=youtube_share;pyWtv9dUPpM]http://youtu.be/pyWtv9dUPpM[/video]
5) Buddhist_fist (Vancouver BC, Canada) spring rate to be determined - awaiting PayPal e-mail and spring rate decision
6) [B][B][B]JLee (SF Bay Area, CA) [B]10KG Front / 12KG Rear - PAID[B][B][B][B][B][B][B]
7) [B][B][B][B][B][B][B][B][B]Jcasanova (Houston, TX) 10KG Front / 12KG Rear - PAID[B][B][B][B][B][B][B][B]
[B]8) [B][B][B][B][B][B][B][B][B]Logan (Seattle, WA) 12KG Front / 12KG Rear - PAID[B][B][B][B][B][B][B][B][B]
9) [B][B][B][B][B][B][B][B][B]FX4BR (La Jolla, CA) 10KG Front / 12KG Rear - invoice sent[B][B][B][B][B][B][B][B][B]
11) KNFX (Houston, TX) [B][B][B][B][B][B][B][B][B]10KG Front / 12KG Rear [B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B]- invoice to be sent
[/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B]
12)
13)
14)
15)[/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B]
Nice, does kido have a video of them testing (drifting) an fx :p
Sent from my HTC_Amaze_4G
brembo's are stupid expensive. the first one you listed is the monoblock caliper which is very very expensive, wholesale is well over $5,500
Ah, monoblock's -- so rookie's territory. Rear=less demand + parking brake to deal with = more expensive sometimes than fronts.
also guys, just one more tip about choosing spring rates, the lower you plan to go the stiffer you need the springs to be. I'm sure this is obvious to most but some may not realize this so just thought I'd mention this here. this would be the main reason to stiffen up the spring rate is to go lower without bottoming on compression and reaching the end of travel.
you and me both brother, life has just been in the way man, as much as I miss it and all, it just can't take priority over more pressing issues atm... hopefully soon man...
12)DESILVAFX35(NEW YORK,NY) 10KG FRONT/12KG REAR, PILLOW BALL MOUNT[B]
[B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B]
[/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B]
[/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B]
They are not needed. But if you want them, they are USD 18 / 2 pieces.
Aero (Andrew) and Kido, both told me they are not needed at all for the FX application. Aero (Andrew) had BC Coilovers and bought the rear extension kit but never installed/used them.
How much is this extension kit and would yall recommend it?
---------- Post added at 03:37 PM ---------- Previous post was at 12:00 PM ----------
* please note that everyone will be getting pillow ball mount (the recommended)
9) [B][B][B][B][B][B][B][B][B]FX4BR (La Jolla, CA) 10KG Front / 12KG Rear - [COLOR=#ff0000]invoice sent[/COLOR][B][B][B][B][B][B][B][B][B]
11) KNFX (Houston, TX) [B][B][B][B][B][B][B][B][B]10KG Front / 12KG Rear [B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B]- PAID
12) DESILVAFX35 (New York, NY)
[/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B][B]10KG Front / 12KG Rear - [COLOR=#ff0000]invoice to be sent[/COLOR][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B][/B]
If the Kidos are set up similar to BC, then I don't even think extenders apply to the FX coils, unless it states it. I think the extenders apply to other models where the rears are internal in the trunk or in the actual interior of the vehicle and need the extensions to make adjustment easier. What I mean by internal, is where the coilover mounts to and where the adjustment dial is. The fronts for the FX are internal and adjustment is easy. But the rears are completely exposed to the outside, so no extenders apply. I'm pretty certain the rears on the Kido are like the BC and this is the only way I can describe now, but I'm sure there is a better way. If this is the case, adjust the rears are simple. I was able to stick my arm and hand through the spokes of OEM 20"s and dial in the level I want. Hope this makes some sense.
