08 FX35 knuckle upgrade using FX50 rotors?
ats1098
Dallas
steve
Read a lot of good info post/threads putting FX50 rotors on FX35 front is no problem but the rear requires just a trim of the backing plate? I see a site conceptZ states that the rear knuckle must be changed on 1st Gen.
Any help or guidance would be appreciated on above and the following.
1. Anyone recommend equivalent after market to doing FX50 OEM upgrade in similar cost / performance.
2. Does the FX50 calipers fit all the way around or same as #1 any recommendations?
I'm not street racing or drive mountainous terrain. Just looking for respectable performance and better aesthetics with all new rotors, calipers & pads.
Steve
I just ordered the czp kit
you need to get turbocads kit because the 1 gen ball joint is smaller then the second generation ball joint mounting hole
