[03-08 FX] BC Coilovers Import Image Racing
Status
Not open for further replies.
BC Coilover for the Infinit FX ? does not even exist
on BC's own website. How is that possible ? I got a customer who's ready to order it but I found no reference anywhere for that to be exist.
His car is a 2010 FX37 AWD and he would even be happy with a housing/spring without the shocks. BC does not list anything for the Fx..:mad.:
2010 is the 2nd gen, which is not made yet...
They are available right now for 2003-2008, scroll all the way down to the bottom in the drop down, it's not all in alpha-order. He's looking for a tester for the newer FX's.
http://www.importimageracing.com/p/BC-Racing-BR-Series-Coilover-Kit.html
Josh -- if you can, put the drop down list in Alpha order, seems to throw off a lot of people.
I randomly came across it when I found it on your site.
Somewhat aggressive Wortex. And that for your very first post here. Next time try to do some research first or read only a few pages back and you would have got all the intell you've needed :tup:
bringing an old thread back up ... everyone still like BC? how do they compare with megan? any reason to do only springs now and then when shocks and struts start to go do coilovers?
thanks!
thanks!
Since you have an 04 it would be best to just switch to coilovers now, you are mostly likely close or over 50,000 which is the recommended time to replace the struts.
+1, i still need to change my stock 77k oem setup to coilovers..
Got the Bc on it as well and love the difference in performance. That is the spring rate and damping is so progressive the car reacts great on the gas.....more direct response......and same with braking. And the lowering is much better then just springs.
Somewhat harder ride then my oem schock with H&R spring set-up but after driving it for a while now i got used to that as well.
Status
