- Miami
- 2004 Infiniti FX35 Supercharged
Authorized Megan Racing NA dealer. Full US warranty. This offer is only available for InfinitiScene members.
$799 for EZII Street Series Kit for 2009-2015 Infiniti FX35/FX37/FX50/QX70(AWD ONLY).
$899 shipped for LP kit for 2003-2008 Infiniti FX35/FX45 (AWD and RWD).
Free tracking and insurance and your choice(please pick one) of Muteki Lug nuts(any color)***, SPC rear camber kit, Megan Racing Rear Extenders or flat rate shipping to Canada($60-$85, please PM me your zip code).
Payment method:
PayPal (no fee for InfinitiScene members)
Feel free to post your inquiries here or PM me with any questions or concerns.
* $35 extra for Chrome Neon and Burned Blue Neon colors
** SR48 locks are available, sold separately in packs of 4.
EZII Street Series Kit(stock picture)
LP Street Series Kit
The Street LP Series is our new Luxury Package, using similar specs & set up design as Street Series, ( not too aggressive) offering spring rates for a more comfortable ride, but still giving you the sporty feel & control.
Megan Racing Coil-Over Dampers are the ultimate upgrade to your track or street car. Featuring 32 Levels of damper force adjustment, full-height adjustment, these damper kits are then perfectly matched with front and rear Pillow Ball upper mounts for camber correction in most applications.
The adjustment of the damper is as simple as can be with a built-in knob at the top of the damper mount for easy access. Simple adjustments can be made to tune to your style of driving and comfort level desired. Single-Adjustable dampers make suspension adjustments easy to tune whether you¡¯re a professional mechanic or an automotive enthusiast with amateur mechanical skills.
The height adjustment is made easy with CNC-Machined locking perches for accuracy and smooth adjustment. You can raise your car up to factory height for OEM appearance with performance handling or you can drop your car all the way down for a formal racetrack and an aggressive stance lowering your center of gravity to gain full potential of your car¡¯s handling capabilities.
On most applications, the Megan Racing Damper Kits come with fully adjustable Pillow-Ball upper mounts to easily tune and adjust your camber. Adjustable camber gives you an edge on most suspension setups, as you can easily tune your car for any ride height which improves handling, predictability and furthermore tire wear, which is a great benefit both on the racetrack and on the street.
The quality and durability of the Megan Racing Damper kits are unmatched. Made of extremely durable Steel and featuring springs that are constructed of SAE-9254 Cold-Wound Steel which are then tested over 500,000 times by compression inspection. With deformation less than 5% and high strength sophisticated surface coating, we stand by our product with our strong warranty.
SPRING RATES:
F: 62mm ID; 220mm length; 8 kg/mm
R: 62mm ID; 260mm length; 12 kg/mm
DAMPER SPECS:
F: 150mm stroke; 320mm length; M2 valving code
R: 147mm stroke; 230mm length; 44R01 valving code
Muteki lug nuts:
SR48
Get race car functional design, OEM quality construction, and car show class looks with the Muteki SR48 Lug Nut Sets from Wheel Mate Performance(Rays,Volk,Gram Wheels). The race car functionality allows for full stud engagement and the open end lets you use extended race wheel studs. The knurled end will also allow you to grip the SR48 Lugs no matter if you’re wearing gloves or not.
The OEM quality construction of the SR48 Lug comes from the use of Cold Forged Chrome Vanadium metal and oversized 60 degree cone seat for better contact on your wheels. The available colors of Titanium, Burned Blue, Pink, Chrome Neon, Red, Blue, and Black, give the SR48 the show car class looks your car requires.
-60 degrees taper seat
-M12×1.25 or M12×1.50 thread pitch
-Cold Forged Chrome Vanadium Construction
-Finishes: Chrome, Black, Titanium, Red, Orange Chrome Neon, Purple Burning Blue, and Blue
-20 48mm open end lug nut set
-comes with 1 3/4″ & 13/16″ dual hex adapter
Available colors:
Black-Titanium-Chrome Neon*-Purple-Red-Blue-Silver Pearl-Burned Blue Neon*-Pink-Yellow
SR35
Light-weight, racing style lug nuts at an affordable price, that’s what the Muteki Open Ended Lug Nuts are about from Wheel Mate Performance(Rays,Volk,Gram Wheels). The cold-forged steel of the Muteki Lug Nut permits it to be smaller, thinner, and lighter than normal steel nuts. Furthermore, the compact size of the Muteki Lug Nut allows it to be used in small diameter wheel holes. The open ended Muteki Lug Nut also allows for longer racing studs and full thread engagement. That, combined with the oversized 60 degree taper seat, ensures that the Muteki Lug Nut will keep your wheel secure. The unique shape of the spline drive will also signify that your wheels will not be removed by a thief passing by.
-M12×1.25 or M12×1.50 thread pitch available
-Cold forged 1008 steel
-Finishes: Chrome, Black, Red, Purple and Blue
-20 spline drive lug nuts set
-Includes a 3/4″ & 13/16″ dual hex adapter
Available colors:
Black-Chrome-Purple-Red-Blue
SPC rear camber kit:
These cams replace the OE camber and to adjustment cams and provide additional camber (±2.0°) and toe (±2.0°) changes. Adjustment slots will need to be elongated using the 85130 rotary file set or equivalent. This is the perfect kit to adjust rear alignment angles for optimum handling and maximize tire life.
Megan Racing rear extenders:
The adjuster extenders allow you to make the rear dampening adjustments without removing the rear wheels. By making two small holes in the rear floor the adjuster extension can be passed through the shelf so that the adjustment can be performed from the inside.
Some kits start at $699 with free shipping:
Audi
02-08 A4 (FWD & AWD)02-08 A4 (FWD & AWD)02-08 A4 (FWD & AWD)
96-01 A4 (FWD ONLY)96-01 A4 (FWD ONLY)96-01 A4 (FWD ONLY)
97-01 S4
09+ A4/S4 A5/S5 FWD/AWD 09+
BMW
E30 (45mm Front Strut exc AWD)E30 (45mm Front Strut exc AWD)E30 (45mm Front Strut exc AWD)
E30 (51mm Front Strut exc AWD)E30 (51mm Front Strut exc AWD)E30 (51mm Front Strut exc AWD)
93-98 3 series E36 (INC M3) 93-98 3 series E36 (INC M3) 93-98 3 series E36 (INC M3)
E34 5 Series 89-95 RWD only
97-03 5 Series E39 (EXC WAGON)97-03 5 Series E39 (EXC WAGON)97-03 5 Series E39 (EXC WAGON)
99-05 3 series E46 (EXC M3)99-05 3 series E46 (EXC M3)99-05 3 series E46 (EXC M3)
99-05 E46 (M3 ONLY)99-05 E46 (M3 ONLY)99-05 E46 (M3 ONLY)
04-10 5-series E60 (EXC M5)04-10 5-series E60 (EXC M5)04-10 5-series E60 (EXC M5)
04-10 E60 (M5 ONLY)04-10 E60 (M5 ONLY)04-10 E60 (M5 ONLY)
09+ 1 series E82
06-11 3 series E90/E93 (SEDAN ONLY EXC M3)06-11 3 series E90/E93 (SEDAN ONLY EXC M3)06-11 3 series E90/E93 (SEDAN ONLY EXC M3)
06-11 3 series E92 (COUPE ONLY EXC M3)06-11 3 series E92 (COUPE ONLY EXC M3)
06-11 3 series E90/E92 (M3 ONLY)06-11 3 series E90/E92 (M3 ONLY)
02-08 Z4
11+ E82 (1M Coupe only)11+ E82 (1M Coupe only)
11+ 5 series (EXC M5)11+ 5 series (EXC M5)
12+ 6 Series (EXC M6)
Mercedes-Benz
01-05 C-Class W203 (EXC C55)01-05 C-Class W203 (EXC C55)
07+ C-Class W204 (EXC C63)07+ C-Class W204 (EXC C63)
03-09 E-Class W211
10+ E-Class W212
Saab
04-07 9-3
VW
93-98 Golf/GTI
99-05 Golf/GTI
06-09 Golf/GTI
10-Present Golf/GTI
08+ CC sedan
Volvo
08+10 C30 hatchback
Infiniti
06+ M35/M45 (RWD ONLY)06+ M35/M45 (RWD ONLY)
M37 2011+ (RWD ONLY)M37 2011+ (RWD ONLY)
03-08 FX35 (RWD and AWD)03-08 FX35 (RWD and AWD)
03-08 G35 (AWD 4 DOOR)03-08 G35 (AWD 4 DOOR)
08+ G37 (COUPE ONLY)08+ G37 (COUPE ONLY)
09+ G37 (AWD SEDAN ONLY)09+ G37 (AWD SEDAN ONLY)
97-01 Q45 (without spindles)97-01 Q45 (without spindles)
97-01 Q45 (with spindles)97-01 Q45 (with spindles)
Lexus
01-05 IS300
06+ IS/GS 300/350/430/460 (EXC AWD)
06+ IS/GS 300/350/430/460 (AWD ONLY)
09+ IS250/350 CONVERTIBLE ONLY
11+ CT200 Hybrid
92-97 GS300/400
98-05 GS300/400
2013 GS350 RWD
93-98 SC300/400
01-05 SC430
95-00 LS400
01-06 LS430
07+
Acura
91-99 NSX
94-01 Integra DC2, EG. EK
02+ RSX
07-12 RDX
04-08 TL
09-12 TL
99-02 TL/CL
04-07 TSX
09+ TSX
Chevrolet
06+ Cobalt SS
10+ Camaro
Dodge
06-10 300M SRT-8/Magnum/Charger/Challenger
11+ Challenger V6/V8
08+ Dodge Caliber SRT-4
13+ Dodge Dart
Fiat
12+ Fiat 500
Ford
99-05 Focus
10+ Fiesta
09-12 Flex
05+ Mustang
Mini
02-06 Mini Cooper Base/"S"
07+ Mini Cooper Base/"S"
Mini Countryman 2010+ FWD only
Dodge
03+ SRT4
Honda
2010+ CRZ Hybrid
88-91 Civic/CRX
92-95 Civic/94-01 Integra
01-04 Civic
02-05 Civic Si EP3
06-11 Civic ALL trim (SI included)
12+ Civic ALL trim (SI included
07-11 CRV AWD and FWD
08+ Accord
03+ Accord
98-02 Accord/99-03 TL/CL
90-97 Accord
88-91 Prelude
92-01 Prelude
05-10 Odyssey
10+ Insight
00-09 S2000
06-08 Fit
09+ Fit
Hyundai
03-08 Tiburon
97-01 Tiburon
11+ Elantra Sedan
08-10 Genesis Coupe ONLY
11+ Genesis Coupe ONLY
09+ Genesis Sedan ONLY
2012+ Sonata
2011+ Veloster
01-02 Rio (EXCLUDES 03-05)
Kia
10+ Forte (KOUPE ONLY)10+ Forte (KOUPE ONLY)
Mazda
93-96 RX7 (FD)
86-92 RX7 (FC)
04+ RX8
90-05 Miata MX5
06+ Miata
99-02 Protégé
03-08 Mazda 3
10+ Mazda3/Mazdaspeed3
05-10 Mazda 5
Madza 6/Mazdaspeed6 - 2wd only
91-99 3000GT AWD
91-99 3000GT FWD
Mitsubishi
Evolution VIII/IX
08+ Evo X
89-94 ECLIPSE (FWD Only)
89-94 ECLIPSE (AWD Only)
95-99 ECLIPSE (2G DSM)
00-05 ECLIPSE / 99-04 Galant
06+ ECLIPESE / 09+ Galant
94-98 Galant / 95-99 ECLIPSE
99-04 Galant / 00-05 ECLIPSE
09+ Galant / 06+ ECLIPESE
02-06 LANCER ES/OZ
07+ LANCER (INCLUDES RallyArt)
Nissan
93-01 Altima
02-06 Altima
07+ Altima
03-06 Maxima
09+ Maxima
11+ Juke
2009+ Cube
11+ Leaf
00-03 Maxima A33
95-99 Maxima
86-88 S12 (S13 fronts needed)
89-94 240sx
95-98 240sx
91-94 Sentra
95-99 Sentra
02-06 Sentra
07+ Sentra
02-08 350Z/G35
09+ 370z
92-96 300ZX (Z32), Skyline R32
89-93 R32 Skyline GTS
09+ GTR R35 (USDM ONLY)
11+ Quest
Pontiac
05-06 GT0
08-09 G8
Scion
03-07 xA / xB
08+ xB
2012+ IQ
05-10 TC
11+ TC
13+ Scion FRS
Subaru
13+ Subaru BRZ
02-06 WRX, 2004 Sti
05-07 STI
08-12 WRX
08-10 STI (hatchback only)
95-01 Impreza
05+ Baja
03-08 Forester
09-13 Forester
10+ Legacy
05-09 Legacy
05-09 Outback
SX4
Toyota
84-87 Corolla (WITHOUT SPINDLES)
84-87 Corolla (WITH SPINDLES)
85-88 Cressida
89-92 Cressida
06+ Camry
89-93 Celica All-Trac
90-93 Celica GT/GTS
94-99 Celica GT/GTS
00+ Celica
03-08 Corolla/03-08 Matrix
02-08 Matrix/03-08 Corolla
09+ Corolla/09+ Matrix (DO NOT FIT AWD or XRS)
09+ Matrix/09+ Corolla (DO NOT FIT AWD or XRS)
90-94 MR2
00-06 MRS Spyder
04-09 Prius
10+ Prius
12+ Prius V Wagon only
06-12 Rav 4
11+ Sienna (AWD/FWD)
93-98 SUPRA/SC300
99-03 Solara
06+ Yaris
etc...
Payment method:
SPRING RATES:
DAMPER SPECS:
Muteki lug nuts:
SR48
Available colors:
SR35
Available colors:
Audi
97-01 S4
BMW
09+ 1 series E82
02-08 Z4
Mercedes-Benz
03-09 E-Class W211
10+ E-Class W212
Saab
04-07 9-3
VW
93-98 Golf/GTI
99-05 Golf/GTI
06-09 Golf/GTI
10-Present Golf/GTI
08+ CC sedan
Volvo
08+10 C30 hatchback
Infiniti
Lexus
01-05 IS300
11+ CT200 Hybrid
92-97 GS300/400
98-05 GS300/400
2013 GS350 RWD
93-98 SC300/400
01-05 SC430
95-00 LS400
01-06 LS430
07+
Acura
91-99 NSX
02+ RSX
07-12 RDX
04-08 TL
09-12 TL
99-02 TL/CL
04-07 TSX
09+ TSX
Chevrolet
06+ Cobalt SS
10+ Camaro
Dodge
13+ Dodge Dart
Fiat
12+ Fiat 500
Ford
99-05 Focus
10+ Fiesta
09-12 Flex
05+ Mustang
Mini
Dodge
03+ SRT4
Honda
2010+ CRZ Hybrid
88-91 Civic/CRX
01-04 Civic
02-05 Civic Si EP3
08+ Accord
03+ Accord
90-97 Accord
88-91 Prelude
92-01 Prelude
05-10 Odyssey
10+ Insight
00-09 S2000
06-08 Fit
09+ Fit
Hyundai
03-08 Tiburon
97-01 Tiburon
11+ Elantra Sedan
2012+ Sonata
2011+ Veloster
Kia
Mazda
93-96 RX7 (FD)
86-92 RX7 (FC)
04+ RX8
90-05 Miata MX5
06+ Miata
99-02 Protégé
03-08 Mazda 3
05-10 Mazda 5
91-99 3000GT AWD
91-99 3000GT FWD
Mitsubishi
Evolution VIII/IX
08+ Evo X
02-06 LANCER ES/OZ
Nissan
93-01 Altima
02-06 Altima
07+ Altima
03-06 Maxima
09+ Maxima
11+ Juke
2009+ Cube
11+ Leaf
00-03 Maxima A33
95-99 Maxima
89-94 240sx
95-98 240sx
91-94 Sentra
95-99 Sentra
02-06 Sentra
07+ Sentra
02-08 350Z/G35
09+ 370z
11+ Quest
Pontiac
05-06 GT0
08-09 G8
Scion
03-07 xA / xB
08+ xB
2012+ IQ
05-10 TC
11+ TC
13+ Scion FRS
Subaru
13+ Subaru BRZ
02-06 WRX, 2004 Sti
05-07 STI
08-12 WRX
95-01 Impreza
05+ Baja
03-08 Forester
09-13 Forester
10+ Legacy
05-09 Legacy
05-09 Outback
SX4
Toyota
85-88 Cressida
89-92 Cressida
06+ Camry
90-93 Celica GT/GTS
94-99 Celica GT/GTS
00+ Celica
90-94 MR2
00-06 MRS Spyder
04-09 Prius
10+ Prius
06-12 Rav 4
93-98 SUPRA/SC300
99-03 Solara
06+ Yaris
etc...
