22" Niche Targe M130
Thanks! They are smaller than stock tires. I wanted a stretch look so I went with the 265. I would of imagine I would have a bigger wheel gap if I went with 285/35 (?)
I don't think so. I think the 265/40 stretched would look smaller because the tire is stretched and the sidewall looks shorter. I think lerry was running 285/40 on bc coils. not sure on his offset though. And what lug nuts did you use they look really good
285/35 would result in slightly bigger wheel gap, it's .5" shorter than 265/40. So there would be .25" more gap. Stretching a tire has no impact on sidewall height, the diameter of the tire can't change, the steel belts underneath are going to keep the same diameter no matter the stretch. But the narrow width of the 265 makes everything look smaller, it's an optical illusion.
Thanks, the lug nuts are just gorilla black lug nuts that I got them with the tires. Thinking down the road I will get mutekis
I agreed with the optical illusion, the tires looks a lot smaller but the gap between the tires and sidewell is not that much bigger than before. I AM lowered on H&R springs as well.
