neva4self
- Queens, NY
- 2009 FX50
Since there are a lot of DIY guys on here I was surprised to find there wasn't already a thread about this. I'm doing a complete brake pad and rotor change for the first time and I'm hoping someone can assist with a walkthrough on bleeding the FX50 brakes. I'm looking to completely flush the system with new fluid. I've done this to my motorcycle countless times so I'm hoping it's a similar process. Here are the questions I have:
1. Where is the brake fluid reservoir located?
2. Is there a master cylinder (like on my motorcycle) and if so where is that located and does it have a bleeder nipple?
3. What order should I bleed the calipers? I know the furthest gets bled first but I don't know which is the furthest and the order to the closest.
4. I have the bigger of the small Mityvac's (MV8121) hand pumps for bleeding brakes, is that going to be sufficient enough to do the job?
Usually with my motorcycle I loosen the bleeder screw then use the pump or depress the brake, then tighten the bleeder screw, then release the brake and repeat until there are no air bubbles in the line. As the fluid in the reservoir gets low I fill it to avoid going completely dry or letting air into the lines. Is the process just as simple with cars?
If any of these questions seem silly, like #2 please bear with me, this is my first car brake job so I'm going to learn from scratch this go round. Thanks.
