BlendMount with MirrorTap mirror wiring help
Sideswipe
Brooklyn
FX35
Sean
I'm about to install a Blendmount with Mirrortap and I don't have a voltmeter here. Does someone know which wires in the rear view mirror are ground and which are +12V so I can tap in? Thanks in advance.
I run it on the ignition that way I can leave my detector plugged in, otherwise it's always on and draining the battery.
Thanks guys
Sent from my SM-G900T
---------- Post added at 11:53 AM ---------- Previous post was at 11:02 AM ----------
Are all 2009 mirror wiring the same or are they different based on the car's options?
Yes, the for 2nd Gen. Tap into the ignition so that it powers up only when the car is running.
There should be just three wires at the connector behind the mirror for all 2nd Gen . What other functions on your mirror other then the regular garage door buttons and auto dimming?
It was the three wires like you said. Radar detector mounted! Thanks again all!
---------- Post added at 06:08 PM ---------- Previous post was at 06:07 PM ----------
Let me know if u need any particular info
