embdenb
- Weeki Wachee
- 2005 FX35
Some years ago when I purchased my FX35 I took it to the dealer for a transmission oil change. I was told that they do not do a simple oil change. I special machine had to be attached to the transmission that would pump and change all the oil, including the torque converter.
Last week I took the vehicle back to the same dealer for transmission oil change. I watched from the waiting room as the mechanic drained the oil from the transmission pan and added 5 or 6 quarts of transmission fluid. No special pump used, just a normal transmission oil change. when I questioned the service adviser he said that was the normal recommended transmission oil change. The complete flush and fill was only recommended when there was an issue with the transmission. BTW the charge to drain and fill with transmission fluid was $171.00 US. :eek.:
Is the complete flush and refill no longer recommended?
