- Westchester, New York
- 09 FX50
iS! I've mentioned a upcoming project and a few shared an interest.... so here she is:
My 1984 300zx 50th Anniversary Edition Z31.
Originally wanted a 240sx (who doesn't nowadays) then looked at 240z's. Both were more than I wanted to spend for such a project. So, I looked at the often-overlooked and underrated Z31 300zx.
So why a z31? The VG30ET attracted me for it's easy power gains after a few minimal mods. The turbo motor can easily make 300hp with 3" exhaust, intake, and by turning up the boost...and the "easy" power adders continue from there...(intercooler, fuel injectors, fuel pump, Nistune software...) Many have 500hp+ on stock internals, some even run the factory turbos at 400hp.... not bad for a 3000lb 2+2
The only problem was finding one in good enough condition for what I wanted to pay. This is going to be a very "hands on" project...
Ended up picking up a local Roller with stock T5 transmission as well as some maintenance/mod work like poly bushings, lowering/sport springs, d/s brake rotors, lightweight Z wheels (not sure from what generation but they are pretty light) plus he claimed all the electronics worked, etc. and it came with tons of extras.
His plans were to drop in a 302 with T5 from an '88 Foxbody mustang...however he stopped after fabbing custom engine mounts because he probably saw that it was more than just a DIY-in the garage project at that point.
So, I bought it off his hands (originally wanted the v8 but after some input from other Z31 drivers and 302 people alike, I decided to stick with the VG30ET...plus I wanted a turbo)
My plans? Right now they are to get the car actually running and to bring it back to it's former glory....with a "modern" touch. Yes, I plan on being able to drift it, yes I plan on trying to make a good amount of power. However, this will be no beat-up drift missile. It'll be a classy bitch.
Let the pictures begin:
Picking her up
getting her to the shop
(drift soarer and yes a real E36 m3)
first night at the shop...
LET THE STRIPPING COMMENCE
OOPS, found some cancer
boxed up all the parts..
re-aligned the hood so it would actually latch closed...test fitting the poly lip kits
same for the hatch...
started grinding and sanding away some of the rust while I wait for the heart transplant VG30ET...beginning the prep process for a full paint job... (not 100% sure on color...was thinking of sticking to the 50th AE theme, however.)
the heart donor:
Motor should be in by the first week of April...trying to get it up and running by mid-april.
This is where the project stands now....
here are a few pictures that inspired me to do the build...
and if you don't get the Harada reference, familiarize yourself with "Wangan Midnight" - the character drives a Z31 50th AE
Also may sway towards a Liberty Walk/ Rocket Bunny / RWB style setup depending on how difficult it is to find parts that will "work" with the Z....and ones there aren't super expensive....
to be continued.......:rotfl:
Picking her up
the heart donor:
