The issue with turn signals is that regular bulbs put a higher load on the circuit, so when you switch over to LED's, the lower power consumption causes the relay inside the BCM to work faster thus making your signals blink faster. To counteract this you need either a resistor or an LED decoder. The only thing I don't know is how the actual socket looks like that plugs into the headlight. i'll be checking that out tomorrow and buying a set. I'll post photos once I confirm this. Reverse, corner lights and fogs aren't an issue since they don't blink and our cars don't have any system that checks if they are functioning correctly like BMW, mercedes, etc have.
---------- Post added at 10:44 PM ---------- Previous post was at 09:58 PM ----------
The curiosity was killing me so I popped the hood and took out the amber bulb from my headlight confirming the plug and the tabs on the plug are exactly as pictured in the decoder above. I'm ordering a set for now and a set of brighter LED amber bulbs. Then when I confirm the decoder works as planned i'll get another set of decoders and LEDs for the rear.
I had an 7440 amber LED laying around and plugged it in, I was getting a hyper blink. So that confirms this.
