Need Help With Reverse Lights Removal!
Bklyn
NYC
Don't know exactly how to install the reverse light on my qx70/fx37 2014. Does anyone has a DIY or something that will help? Also what is better to use for reverse lights LED or HID?:alien:
https://www.infinitiscene.com/search/1/?q=4675-2003-2008-FX-Tail-Reverse-Light-Removal
There is how to remove and access everything.
I have LED's in there right now and they are much better than stock, but I am going to be swapping out for a 15W HID kit purpose built for reverse light applications. I saw these on a friends mazda 3 and it has a similar setup for the reflectors for the reverse lights and they honestly looked soo sweet.
Only concern with the HID kit is installation as it is a little more work then just plugging in a bulb. Its not difficult by any means, but it is a little more work...
Thanks for the reply, but this instruction is for the older body and also for the turn lights. As for the reverse lights are located on the trunk which u need to take off the inside panel of the trunk door. I just wanted to see if anyone has done it and might have a step by step way instead of me doing it on my own without making any mistakes.
Thanks but I can't find the post you are talking about. Also do the plate lights require me to take out the panel ?
How do I remove the plate lights ? I tried to remove it by taking off each clip on both ends but the cover is still attached firmly so I don't know..
where is the link for jbaker wiper delete mod? I can't seem to find it going to have to do this one of these days to swap out my reverse lights for morimotto LED reverse lights
