neva4self
- Queens, NY
- 2009 FX50
Quick video I shot today showing that there is actually quite a bit of room on the 2nd Gen for a fog light bulb replacement or HID installation without actually having to remove the fender molding above the wheel wells. I removed all of the fasteners across the bottom of the front bumper AND THE TWO FASTENERS THAT HOLD THE BACK OF THE PLASTIC THAT PROTECTS THE OIL PAN (I didn't show those two removed) but I did remove them so I could completely remove that portion of plastic. It literally takes 10-15 minutes to remove all of the screws and plastic push clips. Going in this way is very easy IMO as long as you jack or raise the car up enough to have room to extend your arms. I actually am able to get both arms in, I didn't do it in the video because I had to hold the camera, but on the drivers side I use both hands because the bulb's wire harness is short. On the passenger side the bulb's wire harness allows you to pull the bulb all the way out and let it hang down a few inches. Anyway, I hope this video helps to ease the mind of anyone who has wanted to change fog bulbs or install HID's on their 2nd gen themselves but has been leery about it because it's been said that it can only be done from the side of the vehicle through the wheel well. Enjoy!!
[video=youtube_share;odL1jG3phMY]
After shot.
Close up.
After shot.
Close up.
