Nebz
- Orlando, FL
Need help,
I bought wheels for my 05 FXs 24 x 9.5 (+15 offset) tires are 285/30/24. I put them on and sure enough I had rubbing, I'm at stock height not lowered. After taking each wheel off one by one I found the right front was rubbing on the shock/strut. I bought universal 5/16 inch spacers but I could not get the lugs on with the spacer. I'm assuming that if I install spacers than it will work, it looks like most of the posters go with 25mm all the way around. Will that work for me with a +15 offset? I noticed a post that said 5mm is the way to go for a spacer but that seems small.
Part 2, or would my rubbing go away if I replaced the stock shocks and struts with a kyb set? I haven't been able to find any info to see if the strut has a smaller diameter than stock. I just turned 80k miles so I know shocks/struts etc ... Are in my future.
Thanks in advance for advice and now that I finally have a mod or two I can create my garage.
