WiND DANCE
- Central Valley CA
- 2005 FX35
Sup guys, I just got my 05 fx35 with the dreaded Bose system. While checking out the subs in the trunk area I noticed it was cutting in and out.
So I opened it up and behold its the same amp they used in my previous Mazda RX8. Well we had a fix and all it requires is a larger $2 Panasonic relay.
Items needed:
Instructions:
Pictures: (note: these pictures and work was posted by gabrod72 on rx8club.com)
http://www.rx8club.com/attachments/...doors-not-working-$1-67-relay-fix-topside-jpg
http://www.rx8club.com/attachments/...oors-not-working-$1-67-relay-fix-backside-jpg
http://www.rx8club.com/attachments/...not-working-$1-67-relay-fix-relay-removed-jpg
http://www.rx8club.com/attachments/...s-not-working-$1-67-relay-fix-clean-holes-jpg
Sources:
The thread: http://rx8club.com/do-yourself-forum-73/diy-bose-speakers-doors-not-working-$1-67-relay-fix-218790/
Link to the Relay: http://www.digikey.com/product-detail/en/JS1-12V-F/255-2080-ND/648567
---------- Post Merged at 11:48 AM ---------- Previous Post was at 11:42 AM ----------
I just checked the part number Bose has for it, same exact amp as my previous car #255490. So relay should work.
Items needed:
- Your stock amp
- Soldering iron
- Rosin Core Solder
- Solder sucker, wick, or pump
- Digikey Panasonic JS1-12V-F Relay
Instructions:
- Remove your stock amp, becareful with the white connector. It is a little difficult to remove.
- Pry open the metal housing and remove the circuit board from the housing. The main board is held by one tab each side.
- Locate and remove the old grey relay.
- Exam your work, While the area is exposed, you will see 5 empty holes where the old relay was and 5 filled holes right next to it. We will be using the new filled holes. With your wick remove the solder that fills those new holes.
- Solder on the new relay. If you care to, apply a very thin coat of rubber cement to the joints to protect from moisture.
- Put everything back and enjoy the mediocre subs again.
Sources:
