Dallas, TX Checking In
phatdownintx
Dallas
What is going on guys? I found this site searching for some good bolt-ons and rims for my 2005 FX35. It has just shy of 61k miles and runs like a charm. I recently inquired about picking up some 22 inch rims but ran into an issue, or so I think. Will 10.5" width rims fit into the wheel wells w/o modification? Also, what is the best cat back exhaust for these things or should I just go with a y-pipe? Looking for some insight and will appreciate any feedback. Thanks fellas.
:top:
Welcome to the forum! 10.5's will fit, it all depends on your offset. Personally if you can afford it I'd suggest a Nismo system. It will require g35 extensions and some slice and dice but its well worth the effort.
Welcome to iS! There are quite a few exhaust options or can stay simple and just do a y pipe if you're not looking to drastically change the sound/performance. I too vote for Nismo though. =)
Welcome to :iS:. Don't forget to post the pics after you put on whatever new "shoes" you decided to go for.
