Wheel Spacer - Ichiba [HELP NEEDED]
Yiqiao_FX
Ontario
Hey guys,
I am doing some research on Ichiba Wheel Spacer for my 11 FX35 with a 21'' OEM rim... I also have a set of H&R lowering springs that ready to be installed.
I have got :
FIRST
Ichiba Wheel Spacer V.2 (Not sure if it will works though)
want to put both front and rear for 20mm
I think for the pitch thread I will need to choose is the 12x1.25mm but not sure about what the bolt pattern is? 5x100 or 5x114.3 ?
Second:
I have also took a look at this Eibach Pro-Spacer 20mm Spacer / Bolt Pattern 5x114.3 / Hub Center 67.1
Will this work?
OR
If anyone who has done it before, please let me know where and what kind wheel spacer to get. I really want to do it right and safe since it is directly attached to the wheel. :)
I also have a set of H&R lowering springs that ready to be installed. Can I do them all at the same time or separate them into two projects?
My question might be stupid..but I appreciate any ideas and comment. Thank you all in advance.
Will definitely Post PICS when I'm done. :)
