jonv8944s
- Chicago, IL
I know the FX50 has an unfair fight against it, when I compare it to the GTR, but there has to be somethings that can tighten up the handling of the car a bit. Don't get me wrong, its not horrible, but I know the SRT8 we had could definitely out handle it, by a lot.
I realize for me, I should have gotten the Fx50s (does it really handle noticeably better?) but for my wife the technology package was must, and 2011 & 2012 cannot be ordered with both. They are mutually exclusive. (Go try to order one on line with both, you will see).
SO we preferred the tech package over the fx50s, so now I have to see what I can do to tighten up the handling. I was thinking the strut tower brace was a must, but how good is it really?
Is the main issue the tires? I have the 21s, which are all season, which I really want to stay with, but I wonder if they had been 'run flats' with the stiffer side walls, would it corner more 'flat'? I realize its unlikely I can get a better performing all season tire. Should I revert to 20s and get an all season with run flats?
I realize a nice set of coil-overs would likely be the fix, but with no good options right now, I need to look for alternate solutions.
What about stiffer sway bars? Is the fx50S's sway bar any different then the regular fx50 ?
I know there are also other chassis stiffening options for the rear, but I am thinking those are going to be hard pressed to do anymore for rigidity then the stiffness the OEM tow hitch adds to the car by locking in both frame rails in the rear together in a VERY solid manor. Looking at the GTSPEC stuff, I just wonder how much can all those parts really add for improved handling.
I'd even be willing to lower the car a bit (lower center of gravity), but having the camber issues is not something I would want to inherent from such a move.
Appreciate any insight and direction people have on CONFIRMED options. I want real world experience and insight, not some of the 'oh that might work' or 'this could maybe help, try it.' I'm looking to benefit from research already done by members. No reason to reinvent the wheel in this case.
Jon
Jon
