22 Range rover 22x10 wheels to Fit or not To fit?
onmyway
Rochester Ny
Please tell me these will fit. I'm a new guy on the forum and i have been doing research on a nice set of 22's that wont take away from the factory look and I have concluded that search with these wheels. Please tell me these will fit i love them!!! The specs are 22x10" Wheel Offset is 50mm. Hub size is 72.56mm Bolt Pattern is 5x120mm. will these fit with a 20mm 5x114.3 to 5x120 adapter i was thinking about getting 20mm for front and 25mm for rear. I have a awd 2003 fx35
Yes, they will fit. Get 25mm adapters all around, as they will 100% clear the OEM studs.
I run 24x10 +45 on 25mm adapters from 72.56mm to 66.1mm or whatever our hub bore is.
Call Motorsport tech and ask for junior. Don't order via online as you need to discuss stud length cut to OEM range rover length (mine were too long, he knows that). Note studs are different size too and OEM lug nuts are around a couple hundred dollars, if they are the flat mag style and not cone seat.
I ended up using the rims from my old BMW. 22X10.5 +40 in the rear and 22X9 +35 front. The adapters are 5X120bp and 73.1 bore for the rims to our 5X114.3bp 66.1cb and the thickness is 19mm which is the thinnest they make. I used the same studs size too, 12X 1.25. I didn't need to modify the rims at all with the short adapters as my rims already had pockets on the mounting surface so that little bit of the stock stud that poked out past the adapter fit perfectly in the recess of the rim mounting pad. It's a tight fit with the coilovers and 305s but it fits perfect and does not rub at all.
Thanks guys For the help! After the 6 months of looking ive decided to go with a set on 22x10 inch Rinspeed off of a range rover. Got 5 Brand new rims and tires for 1100 shipped couldnt pass it.
flickr.com/photos/77620163@N02/6809994642/in/photostream/
---------- Post added at 08:07 AM ---------- Previous post was at 08:02 AM ----------
Just took a couple off pics. Hope you guys like them. No lowering or anything of that sort its the family vehicle so im trying to keep it simple other then the rims and flowmaster exhaust smh
flickr.com/photos/77620163@N02/6956105251/in/photostream/
