Official: Koso Kustomz Products & Deals Thread
Status
Not open for further replies.
We are now caring a large selection of BBK ( Big Brake Kits )
We are very excited to offer these, we are doing some GREAT pricing!!! PM us for best price:
Some of the brands we offer:
K-SPORT PROCOMP:
[TABLE="width: 95%"]
[TR]
[TD="align: left"][h=2]K Sport Procomp 4 Piston Rear big brake kits[/h]Ksport's 4 Piston Rear big brake kits provide the ultimate in stopping power for your vehicle. Integrating new brake technology into the design of the kits allows for a kit that highly reduces brake fade and continually cools and refreshes the brake pads surface under braking. These brake systems are designed for easy installation with minimal tools required (in most applications).
Our extreme lightweight caliper comes in differential bore configuration. It is machined from aircraft quality billet, weighs just over 5lbs. each, and has machined in protection grooves for the bridge tubes. Aluminum pistons, high temperature seals, and stainless steel brake pad wear plates are also standard on each caliper design. The opposed piston caliper design greatly improves pad wear and caliper rigidity over the OEM design. The stainless steel brake lines stop expansion under pressure.
Most applications utilize the 2-piece floating disc assembly, which reduces weight both rotating and unsprung.
* Denotes OEM Handbrake will not function after installation.
All KSport Big Brake Kits are special order, usually 2-3 weeks out. Please CALL for availability.
2003-2008 FX'S
COLORS: YELLOW, ORANGE, BLACK,RED
_______________________________________________________________________________________________________________________________________________________________________
[h=2]Brembo GT 4 Piston big brake kits[/h]Brembo Gran Turismo (GT) 4 Piston Systems are excellent for stopping power in everyday traffic, as well as superior high performance street and track driving. They are designed to bolt onto the vehicles original suspension, and are fully compatible with the vehicles stock brake master cylinder and anti-lock braking system (ABS).
Click Brembo PDF for the Brembo North America GT Catalog
While most Brembo Gran Turismo Brake System packages have been developed specifically to replace the vehicle s front brakes (due to the high braking demands encountered there), rear brake systems are also offered for selected applications. For vehicles not offering a Gran Turismo System for the rear axle, Brembo Sport brake rotors (slotted or drilled) are available to replace the stock rotors on the rear axle and provide a matched appearance on all four corners of the vehicle.
Gran Turismo Brake Systems packages combine high performance fixed aluminum brake calipers, large diameter 1- or 2-piece vented brake rotors, brake pads, stainless steel braided brake lines and aircraft quality mounting brackets and hardware. (See photo and chart below.) Brake caliper and rotor sizes are selected based on the vehicle s requirements. In most cases, the aluminum calipers are available in red, sliver or black finishes. Additionally, the rotors feature drilled or slotted disc surfaces depending on the vehicle application and brake system selected. All cross-drilled holes are bi-angle chamfered at the rotor s outer surfaces to help reduce the cracking caused by repeated, high stress, high temperature brake applications. Gran Turismo brake discs are coated for corrosion resistance to help eliminate rust and to offer a bold, aggressive appearance to enhance the look of the vehicle s road wheels.
[TABLE="align: center"]
[TR]
[TD="align: center"]
1-Piece Drilled/Vented Rotors
[/TD]
[TD][/TD]
2-Piece Drilled/Vented Rotors
[/TD]
[TD="width: 50px"][/TD]
2-Piece Slotted/Vented Rotors
[/TD]
[/TR]
[/TABLE]
NOTES:
  • Requires minor modification to the OEM steering knuckle.
  • Requires minor modification to the OEM steering knuckle and use of included custom hubs.
  • 1995 E36 M3 models require minor modification to the lower control arm outboard of the ball joint.
  • This system consists only of 2-piece disc assemblies which directly replace the OEM discs.
  • Requires significant modification to the OEM knuckle.
  • This system eliminates the parking brake function.
  • This system is to be used ONLY with OEM rear brakes, not to be used with the rear upgrade kit.
  • This system requires separate hand-brake kit as listed or parking brake function is eliminated.
  • Kit is special order, please allow 4-6 for delivery
A StopTech Big Brake Kit represents the ultimate high performance brake upgrades...StopTech Big Brake Kits exceed stock performance in two key areas: First, larger rotors increase heat capacity, allowing a driver to brake harder stop-after-stop with reduced chance of fade. Second, stiffer calipers and stainless steel lines reduce system compliance, providing consistent pedal feel and confidence-inspiring responsiveness. The key, however, is to increase heat capacity and reduce compliance without upsetting a vehicle's stock front-to-rear brake torque ratio. That is why StopTech developed the Balanced Brake Upgrade design philosophy, which precisely apportions front and rear braking resources while factoring in vehicle weight transfer under braking. In contrast, a brake upgrade that adds too much front torque (as many do), will reduce your car's ability to maximize the traction available from all four tires, robbing you of performance. In addition, a system that uses too many pistons or pistons that are too large will make the brake pedal much more difficult to modulate, limiting a driver's control of brake input.
Key Features
  • Balanced Brake Upgrades with optimum brake bias offer the shortest stopping distance with the best pedal feel.
  • Patented AeroRotors offer the best airflow available for better cooling, less fade and longer rotor and pad life.
  • StopTech provides the stiffest fully-forged aftermarket calipers with patented, removable bridges that provide better clamping under hard braking and less pad taper.
  • StopTech Big Brake Kit components are made in the USA in a 70,000 square foot California manufacturing, engineering, and R&D center.
viewimageresize.asp
2003-2009 FX
[/TD]
[/TR]
[/TABLE]
Just got word that I will be getting some GTSpec bars for the 1st gen. I will find out more this week for you guys. Woooo hooo
Sent from my DROID RAZR 2
Bump, for the newer members.
If there is something BESIDES GTSPEC bars that you guys would like to see a group buy done on, I will look into it, but not GTSPEC again lol.
He keeps saying it will fit the 2008, so I'm not 100% sure. But it will fit the RWD only. They have been trying to find a AWD test fitter.
Also, what would you guys like to see us carry / Sell / Group Buy on? Not GTSPEC lol.
Status
