GTspec special while supplies last
Status
Not open for further replies.
I couldnt wait
---------- Post added at 12:52 PM ---------- Previous post was at 12:49 PM ----------
There's so much bracing on this thing now. Just by looking at how it's installed & placement, I'm sure it's gonna improve the chassis stiffness. This is a good one.
No real review yet, but from what I can tell right off, is that it feels smoother on rough road. This is good.
I couldnt wait
Your underbody is gorgerous dam Chicago weather
You use the rivets where there is only a hole, but not a bolt already. Basically the rivet creates a place to mount the chassis with at that location with a bolt.
Yes. That's an extra rivet.
The 2 rivets will go on the 2 most rear mounting points. The front 2, you can get your finger in the open hole just in front of the mounting point. You can hold the nut by hand. It will thread, & you dont need a wrench to hold it.
Hope that helps clarify
Right on the money :tup:
Couple orders over the weekend. All part numbers are in stock. Getting low on two part numbers. SUS-GTS-1318 AND SUS-GTS-1317.
Thanks guys for all the business :)
Charles
Help guys!! I know I must be stupid or something...but i can't get these rivets to work! I followed the diagram and am doing it right I think but the rivet jst turns in the mounting hole when I turn the nut and hold the sleeve. It's not expanding like it's supposed to...what am I doing wrong?? :(
Is it just immediately falling out? I know one of mine seemed like it didn't stick in well, but when you tighten down the new bolt during installation, it also expands it a little.
Status
