FourXX_50
- Nova Scotia
My OEM tires are just about shot, and after some research, I've pretty much decided that instead of getting another set of 21" tires, I'm going to get a set of Giovanna Kilis 22s with Toyo Proxes II tires.
I want to do a staggered set up, 22x9 with 265/45/22 for the front and 22x10.5 with 305/40/22 in the rear.
These tire sizes seem to be the best match for overall circumference, only out by 0.7% according to the Miata tire size calculator.
This setup would be 1.2" taller than the factory set up which I think will fill out the wheel wells nicely since lowering isn't an option at this point.
I believe the offset on the Giovannas is 40. I'm having a hard time verifying this online, but I'll confirm before placing my order.
The wheel offset calculator states 3mm LESS inner clearance and that they will EXTEND by 23mm for the rears, and 16mm MORE inner clearance and they'll EXTEND 4mm in the front.
I know bobby2478 has ordered 22x10.5s but he's going with 285s all around.
And I know that going staggered is not "recommended" with AWD but it's what I want to go with, and as someone mentioned in another thread, some of the guys here have crazy set ups. But if anyone has experience with staggered setups causing issues I'd definitely reconsider.
I think I've done enough research to go ahead with the order, but I just want to see if anyone has any suggestions, or input before I finalize anything.
