Bigger Calipers
bubito9512
Miami
Hey guys, is it possible to have bigger calipers like AKABONO but stay with the OEM rotors?
---------- Post added at 05:17 PM ---------- Previous post was at 05:00 PM ----------
like maybe calipers from a g37s ?
FX50 brakes aren't cheap. I'd love a set but I don't have the extra dough for that and if I did I would just end up getting a Brembo kit, which are like $3-4k. I don't think you could use the same rotors with the fx50 calipers but I could be wrong. I know the 1st gen brakes are different than ours because I just got a set of cross-drilled/slotted rotors from R1concepts and it was a little more $ b/c their different/newer. Got them in today but wont install them till spring. Also got the G2 paint (silver) just to give the caliper more of a clean look. I'll post pics when I got everything together ... I've been anxious to put it on so maybe it'll be sooner than spring.
The answer should be: dead NO
The FX you have is well worth 30K and yet cheaping out on just bbk "rotors" is unsafe and foolish. Besides, the oem rotors are 13" vs BBK's 14" and differnt thickness I would assume.
Given u're gen2, u're already saving $800 on the rear knuckles (gen1 needs). If you are trying to save, best to convert just the fronts as bbk's.
edit: also by the time have a shop fabricate some custom bracket, it might be equal to the rotor costs (plus some headaches).
well i can get a full bbk akabon kit for $1,000 or $1,200 + $200 shipping... i don't have the extra cash for that right now so i was thinking of the calipers for now, or just wait till i have more cash and buy the full kit..
Stoptech has good stuff but the price on that seems a little steep. It does say to make an offer so I'm sure you can get it cheaper but all your getting is rotors (slotted or cross-drilled/slotted), pads and stainless steel brake lines. I thought you were leaning more toward bigger calipers. I got everything but the brake lines for 350 shipped.
I'd offer them like 400/450 and see what happens.
trying to use akebono calipers on the stock rotors is almost the same as trying to mount 22" tires on your 20" rims... yeah, good luck with that:tongue (2): as soon said, no way bro...
Lots of BBK threads here on IS to review for more info.
Stoptech makes a front BBK kit and NO rear kit for the FX. If you go to Stoptech's site and look for their "white paper" section, they present tech data on WHY rear BBKs don't improve braking performance on the FX - and are for looks only. Here is my particular learning experience, taken directly from the Stoptech website:
This is from Stoptech:
“Stopping power” is an oft misapplied term. What most think it means is more clamping power to push the pads against the rotor with more force, which is only part of the equation. The more correct term is “brake torque”, which is a combination of pressure output of the caliper (controlled by piston size and overall system pressure, i.e. how hard you push on the pedal), the radius at which that force is applied (bigger rotor diameter means more torque if all else is equal) and the coefficient of friction of the brake pads. We are NOT looking to increase brake torque as it will throw off the balance of the brakes. The vehicle manufacturer spent a lot of time and money getting the front to rear balance optimized, and we work to maintain that balance, or maybe very slightly tweak it, which yields the best performance in terms of stopping distance and integration with the rest of the vehicle systems. Adding brake torque to the front (let’s slap on the most pistons we can find) will place too much load on the front tires and likely INCREASE stopping distance and could mess with the ABS. The G-Meter in your butt may think the thing is standing on its nose, which it probably is, but using proper instruments in controlled conditions will show a different result. The over amplified signal from over-sized components will also make the pedal more like a micro-switch, which is also misinterpreted as “Man, I barely touch the pedal and the thing is already into ABS.” Again, the butt G-Meter says “Woo Hoo!”, but is it really predictable and drivable that way? Adding torque to the rear (such as moving the front calipers to the back) can cause rear lock-up and/or adverse ABS intervention and cause the vehicle to lose control. The benefit of a brake upgrade is not dramatically shorter stopping distances, though we do usually see a slight improvement. Buy really good tires and the stock brakes will stop in a measurably shorter distance. What a brake kit WILL provide is much increased heat capacity and better pedal feel due to a stiffer caliper and the addition of stainless lines. The stiffness of the new components does help with stopping distance as the signal from your foot to the tires is shortened due to less loss of efficiencies due to flex in the stock system.
Just to emphasize the point, OE manufacturer’s design all the dynamic control systems around stock components. ANY change to the vehicle may have an adverse affect on how the platform reacts in a panic situation. Sometimes it may be better, sometimes it may be worse. ABS is taking data from the wheel sensors and responding to that data based on how it was programmed with STOCK components. If you dramatically change something, lets say much larger piston volume in the front calipers, as ABS is reading data and trying to correct things, the signals it is sending to the brakes (apply/release/apply/release/apply/release) may not have the expected result due to the increased volume of fluid needed to actuate the brakes and the over amplified brake torque that results. It’s working overtime to figure out if you’re on locking up all 4 wheels on ice or 2 wheels off in the gravel. Add to that aftermarket shocks, wheels and tires, changes to the engine; let’s say part of the dynamic control is to reconfigure the timing to control the engine but the thing is chipped or artificially aspirated… All this is why we stick close to the stock balance on the brakes; we want to do all we can to lessen the impact of our parts on the rest of the vehicle while providing the most benefit in a very controlled manner.
I love my Stoptechs, but it does bother me I have rear OEM calipers. If I had it to do over again I would probably go with AP Racing because front and rear upgrades cost about the same as the front Stoptech upgrade (with rear rotors, pads & lines).
My advice would be to wait for what you really want - save up. It's worth it.
^ Agreed. Brakes are critical, do it once, do it right. I finally pulled the trigger on these ///11020 delivery is set for end January......
