- Westchester, New York
- 09 FX50
hey guys, need some help ASAP
I've run into a problem with my FX in the past couple of days.
I start the car; it starts up totally fine and healthy, and idles just fine at around 1k
However, the VDC off, SLIP, BRAKE, ABS, AWD, Tire pressure, and CEL stay lit on the dash, and the tachometer and speedometer stay at 0 and the display under the tach for the PRND or 12345 displays nothing. Also, the turn signal light does not come up on the dash, but the signals are working. This has happened twice right after starting and once while I was driving. After a few restarts. it would go away and drive fine.
I can put it into gear just fine without any issue and begin to drive, but when it wants to change gears it changes gears HARD and when I put it in manumatic it shifts gears by itself anyway. Also, when I went to brake slightly with the wheel turned, it sounded like the ABS was going off or the power steering pump was making a noise, and felt like there was no power steering. I had to drive like this for a few minutes to get back to my gf's (I'm in PA right now, no infiniti dealer near me)
This also happened the other day, but while I was driving. The car just started changing gears and I pulled off to the side in N while the ABS was going off. After two restarts it was back to normal. This was after trying to jump start my friend's 1990 foxbody mustang with a supercharged 302 @9psi with a dead battery. so I thought I just drained mine...
Thursday I drove 3.5 hours to my Gf's and the car was fine the ENTIRE time. I also drove around sunday and yesterday morning without an issue. it happened again yesterday afternoon.
However, since It happened yesterday, the lights keep coming on after I start the car. I disconnected the battery and did an ecu reset, and now the only lights that stay up are the SLIP, CEL, and VDC off. The codes it throws is U1000 which I think is a grounding issue. (I also have p0430 from my 02 sensor on my HFC...but doesnt have to do with this)
before this week, my car was sitting for about 3 months, started once a week, but for the most part sitting.
Do you guys think this is a grounding issue, voltage issue, maybe I need a new battery?
Right now my car is in my gf's garage with heat, and when I start it the VDC, CEL, and SLIP lights stay on. I havent tried driviing it. It's about 20 degrees out and there isnt as much snow as NY haha
help?
of coourse this would happen to me while I'm trying to sell the damn car......
I need to fix this because In a few days I need to drive 3.5 hours back home to NY...
p.s. NO I HAVE NOT BEEN DRIFTING (plus, my GTRs are still on)
update:
Just checked brake fluid, it's at MAX level, and I looked at the pads with the wheels still on and they seem to be OK...
update:
checked the battery; DC voltage is 14.9 and AC voltage fluctuates between 2 and 5.....battery seems to be ok
help?
update:
update:
