B2autodesigns
- Florida
- 2008 FX35
Hi Guys
B2 Auto Designs is offering Ichiba Spacer kits in two different verisons.
First is the Standard Spacer with longer studs.
Ichiba Wheel Spacers are made from Aluminum/Magnesium alloy. They are incredibly strong and very lightweight. These are hubcentric spacers that is specifically made to each vehicle; will fitted on your vehicle's original hub perfectly without any gap. Wheel spacers move the wheel out from the hub, effectively widening the stance of the vehicle and lowering its roll center. This simple modification increases lateral stability, which in turn provides improved handling & greater safety.
All are Sold as one pair (2pcs) with 10pcs of longer studs.
Offered in
5mm, 10mm, 15mm, or 20mm Kits
To Order
Ichiba V1 5mm: http://www.b2autodesigns.com/product_info.php?cPath=45_48&products_id=320
Ichiba V1 10mm: http://www.b2autodesigns.com/product_info.php?cPath=45_48&products_id=321
Ichina V1 15mm: http://www.b2autodesigns.com/product_info.php?cPath=45_48&products_id=322
Ichiba V1 20mm: http://www.b2autodesigns.com/product_info.php?cPath=45_48&products_id=323
The Second Verison come with the studs already in the Spacer, This kit would require you to take a look at the Wheels you have to make sure that the back pad of the wheel (where the lugs go through) have indentations next to it, allowing the left over factory stud to come through.
Version II wheel spacers are made from Aluminum/Magnesium alloy. They are incredibly strong and very lightweight. Each wheel spacers are two pieces design with pressed studs. Now it's time to bolt-on without any swap studs hassles. These are hubcentric spacers that is specifically made to each vehicle; will fitted on your vehicle's original hub perfectly without any gap. Wheel spacers move the wheel out from the hub, effectively widening the stance of the vehicle and lowering its roll center. This simple modification increases lateral stability, which in turn provides improved handling & greater safety.
To Order
Ichiba V2 15mm:http://www.b2autodesigns.com/product_info.php?cPath=45_48&products_id=314
Ichiba V2 20mm:http://www.b2autodesigns.com/product_info.php?cPath=45_48&products_id=315
Ichiba V2 25mm:http://www.b2autodesigns.com/product_info.php?cPath=45_48&products_id=316
Ichiba V2 30mm:http://www.b2autodesigns.com/product_info.php?cPath=45_48&products_id=2755
Ichiba V2 38mm:http://www.b2autodesigns.com/product_info.php?cPath=45_48&products_id=2756
Please PM me for pricing and question about the best spacer size for you G.
If you are in Central Florida area, and would like me to help you make your G have the best stance possible, or if you need fender Modification to help with you current wheels or spacers. Please email or call me. I have been doing Fender Modification for many years and on a wide variety of cars.
Thanks
Charles
Offered in
To Order
To Order
Thanks
Charles
