Parking LED Lights
I changed mine to 4 LED high powered bulbs. Mine aren't from eBay either. I bought them from Vleds.com:
not exactly what you want just thought of sharing
in headlights i've got this:
and in rear lights i've installed HID:
That looks sweet ! How hard was it to replace the little bulbs ?
Also , anyone knows what they mean when they list these bulbs as "NO OBC ERROR" ? TIA!
Not hard at all! All you have to do it pull back the inner wheel well lining to get full access to the back of the headlights. I'd advise not changing the lights from through the engine bay, just do it from the wheel well area. To remove it, just unscrew the two screws holding the black trim piece on around the lip of the wheel well. Then just pull on it carefully and the clips will pop out. It's as simple as that:tup:
No OBC Error is referring to the bulb out warning system on BMW's and Mercedes. Don't worry about that though cause Infiniti doesn't have a bulb out warning system.
Fire0nic3, I always changing them throught the engine bay. it takes 5 min:)
You can change them through the engine bay. There is just one problem though. It's hard to see what your hand is touching and hard to get a good view of the back of the headlight. The space behind the headlight is kind of tight. If you do it through the wheel well you can get a good view of the back with lots of room to work with.
Fire0nic3,you're right. I'm always in a hurry so I quickly changed through engine bay. moreover, there is nothing to break (I mean clips)
might want to be careful with buying the really cheap ones from ebay.i bought a pair and it blew my dtrl fuse.I ended up taking it out and just keeping my hid headlights and hid fogs no one can ever tell if i have park lights or not =]
fxp35818 - what bulb type is that? Looks really well lit up! I had the 6LED wedge bulb in my G, similar to the 4led bulb that Fire0nic3 has.
