TK76
- Ashburn,VA
Can someone please post a DIY for installing Dynamat on 09+ FX. Thanks.
actually i was thinking only putting the dynamat or some sort of foam to prevent the driver side door from rattling whenever i turn the bass up...sorry if that was unclear, i'm not bothered by my exhaust
Actually I don't agree with FireOnic3 - Do you actually know any 2nd gens that have tried insulation and said it didn't help? I Seriously doubt it.
Insulation will absolutely help any car. Simple physics - the material attenuates resonance to reduce noise in the cabin...period. Doesn't matter what other kinds of sound deadening materials are already there. In fact, Dynamat actually recommends 3 layers of material in some areas for maximum benefit. - Mat, liner, pad. Adding to what you already have will have an improvement in stereo sound quality and reduced road noise.
Same goes for 1st gen - the OEM sound deadening is present everywhere but a layer of Dynamat absolutely helped mine.
Fact is, all car manufacturers use materials and installation processes with considerations to cost and manufacturability. The OEM sound and vibration attenuation does a good job until you start adding bolt on mods. Then the OEM insulation isn't designed for that level of noise & vibration.
As for "weight" issue - we're driving an SUV. 36 square feet of Dynamat weighs in at about 15 lbs.
The DIY for the 2nd gen is going to be the same as the first gen. Any service manual will tell you how to remove the door panels. I bought my manual for 5 bucks on eBay.
Drone in the 1st gen? Wow - you're the first person I have ever heard say that.
I already explained that putting Dynamat in the 09+ FX is not going to help alot. Sure it may quiet it down just a tad bit more, but not to the standard you want it....
...Not only does the carpet padding have a sound blocker in it, but it also has another layer of floor foam under it sealed to the frame and floor pan. ...
...All your going to be doing is adding more weight to the car and tear the interior apart...
I highly doubt any second gen owner on here is going to rip their new FX apart to do that themselves.
I've driven an 03 FX45 and it did experience alot of exhaust drone at lower RPM's when cruising. It was very relevant when sitting in the second row especially. Maybe it's just that particular FX, but it's just my experience.
Second I do know someone that used something similar to Dynamat on a 2nd gen. My neighbor had something called brown bread and Bquiet stuff, I really don't know what it is but it's a popular alternative to Dynamat with excellent reviews. Anyways the shop that did his stereo install also lined the front and rear seats along with the doors, trunk, and spare tire well. There wasn't a big noticeable difference in road noise when compared to both of our vehicles. The stereo improved drastically, but road noise wasn't reduced any better than what my stock FX is.
Third I never said it won't help the car, but "IMO" and "my experience", I really don't think it's going to make a HUGE impact.
But if by all means he wants to, then let him. I'm just giving an opinion.
Third I never said it won't help the car, but "IMO" and "my experience", I really don't think it's going to make a HUGE impact. But if by all means he wants to, then let him. I'm just giving an opinion.
Great responses, still no DIY. What do you guys think about having Best Buy install the dynamat?
not on mine....everything vibrates when I have it all the way up with aftermarket sub, but no rattles.....no dynamat
you sure it's not your sunglasses or something in there rattling...maybe they are placed in there?
my plate doesn't rattle either...I just have a plate though, no cover and you should have these rubber stoppers behind your actual plate...should hear no rattle at all outside the car either with sub turned up all the way.
