Will G37 BBK Fit on My 08 EX35??
SDMF
Vancouver BC
Hi
I have an 2008 EX 35 and want to upgrade the BBK from the G37.
Anyone know if it will fit the EX? I emailed riverside infiniti and they said it will fit.
I am running 20's right now and will have 18's with 10mm spacers in winter.
Please help. Thanks!~:wink (2):
Does that mean the EX share the same rear rotors with the G37 AWD?
I understand that the G37 BBK does not come with the AWD model.
So the rotors come with the BBK will not fit the EX, is that what it means?
Any adjustment I can make to make it fit.
BTW, where can I find these parts numbers??
Thanks a million!~
Yes the EX and the AWD G have the same rotors . As far as I know these *kits* will bolt on to a non-sport model with very little modification
" works with original E-brake system...Note : dust sheilds will have to be removed or cut for calipers/rotors to clear "
http://conceptzperformance.com/Cart/description.php?II=2920
---------- Post added at 05:42 PM ---------- Previous post was at 02:33 PM ----------
Hi
18s might be a tight fit in the winter
I have a PDF for the brake fitment but i have know idea how to post it
Thank you for your information.
If I were to buy the brake kit from conceptzperformance, should I upgrade the brake lines?
Is the Stoptech stainless steel lines a good buy??? It it universal fit?
///9268
This is not the thread i was looking for but still some good info on SS brake lines.
There is another thread somewhere with a lot pros and cons on the SS lines but I dont remember where i read it ,Maybe some else will post it up if they know what im talking about.
///9268
Thanks. I guess I will order the Stoptech SS Lines as well as the BBK.
Too bad you're not in SoCal. Rotora is looking for an EX35 for R&D.
I know. I proposed a journey to California with my wife and her answer is " get out of here"....
If I do not want to trim or remove the dust shields, can I buy the OEM dust shields for 2008 G37 to accomodate the bigger rotors? Are they universal fit but just bigger in size? Do I need both front and rear dust shields?
Thanks a million guys!!~
I doubt you will need front sheilds the FX takes the rotors no prob with no modifications, although I have no first hand knowledge of this on an EX or G :tongue (2):
In the rear I am pretty confident you could use the sheilds from the G37. the 08 G37 and 08 EX both share the same Hubs and Ebrake ... but I would test fit first if I were you
Finally got my EX back yesterday...car not washed yet..so just two pics...more to come...thank you for all the IS guys for their contributions...
