FX Strut Bar
Assuming it attaches the same way the 1st gen does, you can see it would need some bends in there to fit over the engine cover.
The 09 FX mounting structures are the same with the EX. The only problem is with the length. I will compare it tomorrow with my mother's EX.
Pics:
09 FX35
EX35
Ok, so i measured the lenght between the mountings and is the same aprox 100 cm. Also i measured the clearence over the engine. It's about 13 cm on both so i am pretty sure that the strut bar will fit...
there's a metal pipe that travels right over the driver side strut tower. I don't think most strut bars can fit, unless the mounting supports are hollow and allows the metal pipe to pass through.
