it is impossible for struts with 100k miles to still be good. maybe there not leaking & maybe your still kinda riding OK, but there is no way to inspect them with certainty & say there OK without removing them & putting them on a shock dyno which is of course not even worth considering. the wear happens inside at the internal seals that you can not inspect at all & it is impossible for them to still be fine. I personally guarantee you that if you did swap them out you would be amazed at the difference & your fx would feel much "newer" & you will realize then just how much your struts are deteriorated now & you will say wow, I shoulda did this a long time ago.
the problem with shock/strut deterioration is that it is so gradual that you will never actually be able to feel that they are deteriorated or ever feel like anything is wrong, you drive it each time & each time it feels the same, but if you could get out of your fx now & step into it from 4 years ago you'd realize the difference right away.
even at 60k the struts are deteriorated to the point that a new set would be a very nice improvement, but at 100k plus, big big difference...
