IMO In order to take advantage of the power a turbo set up can generate, upgrading the engine internals is a must. Also, once you go turbo the OEM ECU won't be able to handle the massively changed system. Fuel delivery upgrades (pump, rail & injectors) would also help take advantage of what the turbo has to offer. Finally, you'll need a tune to take advantage of the exact modifications you have made. The purpose of the tune will be to set protection limits for the engine so that it's not possible to get too close to the physical limits of the weakest link in the drivetrain. A good tune can lower the chances you'll blow the engine, or lower the chances for premature wear. If you look into turbo kits, aftermarket engine management, fuel delivery and parts for upgrading the engine (plus all installation costs), I would guess you are going to need somewhere in the neighborhood of $15,000.00. There's a lot of other systems impacted by installing high capacity forced induction.
This is really the reason to do the turbo or not - if the cost is worth it to you. This is not an investment you can count on getting back even if you sell the car. If you can afford it and it's what you want (and your wife won't kill you) then do it up, bro!!!
My plan is still for a turbo kit, but now I'm thinking it's still going to be a while longer. That way I can take a look at every single system to make sure I'm not missing anything.
