FXtion
- sherman oaks, ca
My FX is coming up to the end of Warranty so I figured I take it to the dealer to get everything that I can fixed before the warranty is up.
I wanted the follow done.
1. Faded Door Moldings
2. Bubbled Dash
3. Fuel Level Senors off by 1/4 tank.
4. Diff bushing is leaking
5. Driver Side does not lock/unlock
6. passenger side Headlight comes on when cold, but not when warmed up
7. driver side rubber molding under the door is ripped
I went there to check on things to day and here's what they are telling me.
1. Replaced moldings
2. They cannot replace the dash since they cannot get if out of the car (because of the doors). I'll need to some how get it out myself.
3. They wont replace the Fuel sensor because the fuel pump is modded.
4. They wont replace the Diff bushing because of the rear GT Spec Braces
5. They wont replace the Door Solenoid because it's been modded. (they agreed to change it at the end)
6. They wont touch the head light because the lights are modded
7. Replaced the rubber molding on the door.
My service adviser said that if I get the braces off, another dealer my get the bushing replaced. Also, the "fuel Send unit" and the Fuel Level Sensor might be something another dealer might be able to over look. Also the HID problem might be looked at by another dealer.
Is there a Mod Friendly dealer in So Cal that I can take my FX to that will over look the mods?
Also, anyone ever taken the dash out? Where can I get the diagram?
2. Bubbled Dash
