- Vancouver, Canada
I went do some grocery shopping with my family yesterday. The FX was just parked on the side of the street. Came back in 20 mins and started the car (Still in park mode). VDC, SLIP, Engine Service, Tire Pressure , Hand break lights are all on and flashing. All the meter readings are going up and down like crazy.
I shut down the car and started the engine again. Now, Engine Service, VDC and SLIP lights were on and solid. The car was still driveable. Drove it back to my house and turned off and restarted the car again. Only the Engine Service light was on solid, VDC and SLIP were gone.
Brought it to the dealership this morning. They said the error code is U1000. And they said it is normally a grounding issue and they suggested I remove all the grounding wires (I installed the 10 wires grounding kit like 2 months ago, everything has been fine till now. No other modification after that.) The mechanics said resting the Engine Service light should resolve the problem, if the Engine Service light is on again, just remove the grounding wires and clear the codes and either way doesn't affect the driving.
So I paid the labour for resting the error codes. On my way home, the VDC and SLIP lights were on and solid again when I stopped the car at the intersection (No Engine Service light this time.) Just about 1 km from my house, the Handbreak light, Tire Pressure, VDC, SLIP and Snow lights are on and flashing. When I hit the gas, the car is applying brake itself, driving is resistive.
Managed to get the car home and restarted the car again and now only solid VDC and SLIP lights were on; the rest of them were gone like ghosts. Called the dealership, they said they don't know about the flashing lights but solid VDC and SLIP means problem with brakes and suggested me to check the brake fluid.
I checked the brake fluid. The color is gold and clear and at MAX. No fluid leak on my car at all. And the rotor seems to be clean and evenly scratched, so no alignment issue. Brakes were done within a year. Now I don't know what to do!!! :tears:
Could it be a battery or alternator isssue? And advices are helpful and greatly appreciated!! (Sorry for the lengthy post!!)
