My engine smells
fxride
NY
I dont know. My engine smells weird. I am wondering if its because the car is new to me but the smell seems like a burning something. should there be any smell coming from the engine?
Either 1: excess coolant spray is burning off or 2: oil is being burned off. Either way it's most likely something in contact (whether liquid or not) with exhaust piping. Lastly, it could be an exhaust leak way up front (header gasket or where header meets catalytic converter) whether through a flange or just a straight hole.
Do you ever see any minuscule amount of smoke coming from under the hood, especially when you've driven for a while and then pop the hood while it's still running when you park?
also very common is the possibility of a plastic bag stuck to hot exhaust, then, every time it heats up you get a burning smell till either it all burns off or is scraped off...
i get rotten egg stink from my car when i beat on it real good. does that mean my cats are shot? or on their way out? my warranty is up, but aren't cats covered by law even after the manufacturers warranty ends?
Dude the same thing happens to me but it only makes the rotten egg smell when i drive like on the freeway or highway. Always is a rotten egg smell. All my friends said it was the cats making that smell so im thinking my cats are done or not working properly. maybe time to get hfc :D
cars..rotten egg. lol i gotta pay more attn to this. i thought the other person up top was joking when he said rotten egg.
Check the cabin filter as well, it could be as simple as that.
You may still be under warranty for cats
•= Long Term Federal Emission Parts covered for 96 months/or 80,000 miles.
[SIZE=1]
[LEFT][COLOR=yellow]MAINTENANCE SERVICE AND
REPLACEMENT PARTS[/LEFT]
[LEFT]WARRANTY PARTS LIST[/LEFT]
[LEFT]• Fuel injection system[/LEFT]
[COLOR=yellow]Engine control module/onboard diagnostic device​
• Oxygen sensor(s)
• Mass air flow sensor
• Intake manifold
• Throttle body
Catalytic converter(s)------------------------:top:
• Exhaust manifold
• Exhaust tube from manifold to catalytic converter
• Camshaft position sensor(s)
• Crankshaft position sensor(s)
• Spark plugs, ignition coils and wires
• Evaporative emission control system
• Fuel filler neck restrictor and check valve
• Fuel tank and filler cap
• Positive crankcase ventilation system
• Exhaust gas recirculation (EGR) control system
• Hoses, clamps, fittings, tubing, sealing gaskets or
devices, and mounting hardware used in above
systems
• Vacuum and temperature sensitive valves and
switches used in above systems
• Electronic sensors and controls used in above
systems
2004 INFINITI FEDERAL VEHICLE EMISSION CONTROL WARRANTIES​
•[COLOR=#231f20][COLOR=yellow]= Long Term Federal Emission Parts covered for 96 months/or 80,000 miles.
[/COLOR][/COLOR][/COLOR]
[/COLOR][/SIZE]
How do i know for sure that it needs to be replaced though? is that what the egg smell is telling me? also, won't the dealer just try to blame it on my y-pipe and muffler that aren't stock.
I had mine checked at the dealer for no charge since the cats are covered by long term emmission warranty.
