it varies how much power it diverts to the front... it is rear biased so it will under normal conditions divert all power to the rear, but, it's still in the drivetrain so it still takes it's toll... & yeah, it does not transfer power to the fronts at higher speeds unless there is slip. it can divert 10%, 20%, 30%, 40% or up to 50% of the torque to the front wheels on demand & as conditions dictate...
when I first got my fx I kinda wished t was rwd instead of awd for performance reasons, but that's because I considered the awd setup to be similar to say a Yukon or a Tahoe or a 4 runner or something... now, after driving my fx a little over a year through many different conditions I am more satisfied that it is awd, it's not so much like a truck awd, it's more like an Audi quattro awd instead.
I drive fast & even in the rain I like to push it to see where it's limits are. the only car till now that I have been able to really go full speed in the pouring rain in the left lane where there can be huge spots of standing water was a v8 quattro that I had.. it was very stable even going through standing water in the left lane while under throttle... it may have hydroplaned a little, but it was very controllable & stable feeling, it reminded me of a jet ski, I mean when you hit heavy standing water in the left you just had to steer right slightly to compensate... there aren't too many cars that can do that, some cars will want to suck you into the guardrail or throw you around to the point of it not being stable, predictable & safe... well, the fx is like the quattro in that regard, it is very stable under power through standing water in the rain even at high speeds & under throttle... yeah, a lot of this is Dependant on the tires too, but the way the drivetrain transfers power to the wheels is also a factor when under throttle, the fx awd is a sick system & it works well when pushed to it's limits...
the added weight & the added drag of the transfer case will def make an awd a bit slower than a rwd in ideal conditions, but in less than ideal conditions the awd can def have the edge...
