Rim Weights
fxlr8
Staff
Administrator
Please post up if you have additional information (from actual rims you have weighed). Provide the size, et, material, and weight. Thanks
03-05 FX Stock 20's - 20x8 et40 - Cast - 32lbs
03-05 FX Stock 18's - 18x8 et40 - Cast - ??
5zigen Gravis - 20x9.5 et25 - Cast - 34lbs
5zigen Gravis - 20x9.5 et38 - Cast - 32lbs
A
ASA JH8 - 20X9 et45 - Low Pressure Cast/Shot Peened - 27lbs
ASA JH8 - 20x10 et50 - Low Pressure Cast/Shot Peened - 29lbs
Assanti AF-116 - 22x9 et35 3 piece - Forged - 37lbs
Axis Titan - 22x9 et15 - Cast - 41lbs
E
Enkei GTC 01 - 20X8.5 et40 - MAT Alumminum - 24.3lbs
F
Forgestar F14 - 20x10 et45 - Flow Formed - 26.3lbs
G
GTR (OEM Rear) - 20x10.5 et25 - Forged - 27.8lbs
I
iForged Variant - 22X11 3 piece - Forged - 39lbs
iForged Variant - 22X9.5 3 piece - Forged - 38.5lbs
M
Moda 220 - 22x9.5 et36 2 piece - Low Pressure Cast Center/Forged Barrel - 43.5 lbs
O
OZ Canyon ST - 20x9.5 et40 - Low Pressure Cast - 36.2lbs
OZ Ultraleggera - 20x8.5 et25 - Low Pressure Cast/Shot Peened - 25lbs
S
SSR Werfen GT-03 - 20x10.5 et43 - Semi Solid Forged - 30.8lbs
my maya dtv's are 26-27lb's or so in 20x9 from what I can gather on the web, big difference with these to the stockers, you can really feel it, both when mounting AND when driving...
03-05 FX Stock 20's - 20x8 et40 - Cast - 41lbs
03-05 FX Stock 18's - 18x8 et40 - Cast - 35lbs
OZ Canyon ST - 20x9.5 et40 - Low Pressure Cast - 42lbs
OZ Canyon ST - 20x9.5 et40 - 42lbs[/quote]
MAYA DTV'S - 26-27lb's or so in 20x9 from what I can gather on the web
ASA JH8 - 20X9 et45- 27 lbs / 20x10 et50- 29 lbs - 1-piece low-pressure casting and heat-treated
IForged 22X11 3 piece, style: variant, total weight 39lb's...
iforged 22X9.5 3 piece, style: variant, total weight 38.5lb's...
both verified on a good acurate hanging scale...
tires:
yokohama advan st, summer ultra high performance:
265/35-22 : 33lbs
315/30-22 : 44lbs :eek:
5zigen Gravis - 20X9.5 et 38: 32 lbs when I weighed them right after I got them.
I have individual weights of the seperate components , from the centers to the outer rims to the bolts themselves, but I'm sure no one cares so I just gave total weight:tongue:
if you want to add my offset though, it's +48 rear, +32 front...
FX50's superlight 9.5" x 21" Enkei's WITH P265/45R21 all season tires (not broken down by wheel and tire) Weighed by Edmunds on a bathroom scale -73 Lbs.
Does the width on this wheel sound correct? Most other specs show it being narrower.
my front tires are 265 & there on a 9 1/2" rim, which was right in the middle of the specified range for that tire. there def either 9 or 9 1/2, & I'd believe the 9 1/2 sounds believable from how they look to me really... there pretty light, about the weight of a decent 3 piece 22...
