Okay I'm still trying to figure this out. As far as exhaust applications are concerned, will G35 sedan or coupe exhausts work on our FXs? Any modfications needed? As far as the Nismo, is it basically a 350Z application with pipe extension? If so where along the piping are the modifications needed? What about the mount flanges?
The G-Coupe & FX "ARE" the same exhaust, less the extra length in the tips. Good question, why would you want to modify one? Maybe you meant something else in your post?
Calsonic is the brand, & they follow the same path
I guess what I am trying to figure out when selectiing an exhaust for my FX35 is which application (G35c or 350Z) to go with because I dont see very many just for the FXs. So gto-dave, you are saying we should shop for G35c applications since they are technically the same? I know the 350Z and G35c are different in length and flange points and it makes more sense that the longer G35c application fits our cars. As for the Nismo, dont they just make it for the 350Z only? If so then you guys with it on the FX35s must have had to extend the piping right?
You are correct, both will work but for 350z exhaust you will need an extension:
http://mynismo.com/products/?id=4404&rsku=0
Also, typically the y-pipe needs modifications to fit an AWD FX. Also note that even a G35c exhaust, you will need to extend the tips.
You can always just go for an exhaust made for the FX35 (stillen, HKS).
