Differential / Transfer Case Capacity
vicdub85
Los Angeles
2013 FX37
Maintenance manual doesn't state how much capacity each holds. Does anyone know?
Transfer Case
Front Differential
Rear Differential
I changed my rear diff oil in my 2005 FX35 and drained approx. 2 liters when i wanted to fill i could hardly put the whole 2 liters back in it. At first it already started to ran over at 1600ml by closing with the bolt every time (and ofcourse it has to settle in) i succeeded to fill at 1850ml which should be sufficient.So i dont understand that it was at first filled at 1600ml? It is in fact impossible to fill up higher than the refill point.
Does anyone has an explanation.
I can't see how one can fill pass the refill port. Unless they tilt the car such that the fill port is up higher than normal position.
I wouldn't worry too much about it.
Make sure you're on level ground...
Hi, I'm going to change the fluids on my 2010 FX 35. with 40k miles on.
I read the char, that I found the transfer case is using the Matic J fluid. Tranny is using the matic S.. they use two different types ?
Also I see the front diff using 80w90, and rear using 75w90.. will I have issue if I use 75w90 on both?
Pls advice
My FX is RWD. My understanding is I only have rear differential to worry abt? There should be no front differential or transfer case correct?
