LSX FX
Insane modifications. LSX builds, interior overhauls and just absolute badass nonsense.
Infiniti
Fx35
Engine-Drivetrain
Vortec 6200 - 6.2 L92 (Aluminum)
VVT Delete
TSP LS3 Stage 1 Cam w/ Valve train kit
25-TSP225236-112-3B
225/236 .629"/615" 112 LSA
0.660 Dual Valve Springs
Rocker Arm Trunnion Upgrade
Stage 3 Frankenstein LS3 Ported Heads
Milled “0.020 (65cc)
ARP Head Bolts
LS9 Head-gaskets
LSXHR Intake Manifold and Fuel Rails
50lbs Injectors
Holley Raised Valve Covers in black
Granetelli 103mm Throttle Body
5” Cool Air Fender Intake
3” Aluminum Radiator
Oil Cooler with AN lines setup
Longtube Headers
3” Exhaust w/ Hi-Flow Catalytic Converters
6L90E Transmission
3400 Stall
6L90E Transmission Gear Indicator
6l90E Transmission Radiator/Cooler
Lokar 6” Shifter
P, N, R, D, and S mode tuned into shift module
Aluminum 5” Driveshaft
3:69 Rear Diff
Tomei LSD
FX45 Axels
Wheels-Suspension
R35 GTR Premium 20” Wheels
Akebono Big Brake Kit
Slotted Cross-drilled Rotors
BC Racing Coil-overs
Custom Rear Drag Control Arms
FX37 Rear Sway-bar
Electronics-Lighting
Column Mounted Paddle Shifters
Interior-Exterior
Mitsubishi Evo 8 Recaro Front Seats
LSX FX
Table of contents
Gregory Wilson
