Best OBDII Scanner that can check everything?
superwario
st louis
2011 FX35 AWD
Hey guys,
Where can I get the best OBDII scanner that can check everything including seeing what mileage (internal odometer) is stored in the car's ECU?
Thanks!
i've used the scan gauge II before and it works great. has a lot of features to it such as checking codes and reseting them. You can also check stuff like water temp, gas mileage, voltage, etc... I'm thinking of selling mine so if you're interested, let me know.
Thanks!
No off the shelf sub $5000 scan tool will get you that. Hell i dont think the Nissan Consult can get you that. ECU are coded and can be reprogrammed to say whatever they want it to say. But there is no trace of what your REAL mileage is. When something like your cluster goes bad they get a brand new one with 0 miles on it and they program +/- ball park of your actual mileage.
A scanner is only as good as the person reading the information. Newer cars like your 2011 will show more PIDS vs older cars like my 2005. To get a simple CEL Pxxxx code any $20 reader can get you that. The more $$$ you spend it will more info you get but its not exactly common sense, if you have o2 sensor fault, you look at the voltage from that sensor and its at a .2-.3 V do you know what that means? Look at your short term fuel trims and it shows 11.2
Scangauge, those android BT ebay scanner for $20. They are very user friendly and will get what most people need, which is reading and clearing faults and see what your AFR is. I would say they are neat little things to have but you might find it lacking in some areas.
Wow thanks for taking the time to give me that info! So if someone rolled back a car's odometer there's no way to look at the mileage aside from just taking a look at the digital cluster readout? Even on new 2011 cars? You would think there would be more consumer safeguards than that so that people aren't defrauded.
I will call nissan/infiniti tomorrow and see what this "nissan consult" computer can and can't tell me, seems interesting...
