pros and cons ***SPACERS***
  • Thread starter Thread starter FXPS
  • Start date Start date
F
FXPS
Guest
hey guys iam deciding if i should get wheel spacers or not? can you guys tell me some pros and cons about it?
will spacers work with the stock 20's?? and do you think they would look good??
also if you did put on a BBK without the spacers with the stock 20's would you get any rub or what??
Spacers make the stock wheels look much more aggressive. Most likely any BBK will not clear the stock wheels without spacers.
Go with a quality set, HR's are highly rated. Once installed make sure you take them in after 45 days to be re-torqued.
+1-I ran the 20's on mine and were I to do it again I would go with 25's. With the 20's the wheels are tucked in just a hair too far still.
Just make sure that if you do get them installed that the center hub ring is flush and your wheels mesh well with the spacers...
If you baby stars to drift a little to either side you will need to reinstall them..
One last thing, if you do get spacers be prepared to upgrade to elongated bolts to accommodate the spacers... total cost for the upgrade could run you about 200.00 depending on where you get the install done.
